CAT D4G Starts but does not move
Discussion in 'Dozers' started by JuanSpringCat, Feb 4, 2020.
Tags:
  1. JuanSpringCat
    JuanSpringCat New Member
    Feb 3, 2020
    4
    Spring TX
    The engine starts and blade moves, but park brake light is ON, it does not release. Can someone please share the electrical schematics of D4G (cat00d4gJ FDC00364). It does not move forward nor backward.
  2. Tyler d4c
    Tyler d4c Senior Member
    Mar 3, 2016
    254
    Salix Pa
    If it's a hystat and quit all at once the plastic pump driver plate most likely failed
    DMiller likes this.
  3. JuanSpringCat
    Feb 3, 2020
    4
    Spring TX
    how do I know?
  4. JuanSpringCat
    Feb 3, 2020
    4
    Spring TX
  5. JuanSpringCat
    Feb 3, 2020
    4
    Spring TX
  6. Tyler d4c
    Mar 3, 2016
    254
    Salix Pa
    Need to see if the pump is turning at all I'm not sure where to see it at all I'll do some research
  7. Mobiltech
    Mobiltech Senior Member
    Jan 15, 2014
    1,142
    Sask.
    On a d5 i think you lose blade lift too when the coupler fails. Not sure if the d4 is the same.
  8. partsandservice
    partsandservice Senior Member
    Feb 14, 2011
    747
    Georgia
    The hydraulic pump for blade is on the engine accessory drive. Blade functions will operate with striped drive plate. Park break light stays on because there is no brake pressure , because the drive pumps are not turning. Remove or slide forward the engine rather than drive pumps to avoid contaminating the drive system. That method has been mentioned on the HEF before and I use it as well.
    DMiller likes this.
  9. Tyler d4c
    Mar 3, 2016
    254
    Salix Pa
    You should still have the blade working as the pump is ran off the timing gears on the engine
    DMiller likes this.
  10. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
  11. Mbar
    Mbar Well-Known Member
    Dec 15, 2018
    106
    North Carolina
    Just dealt with This. Open door on right side of machine and check pressure on taps 3 and 4. Should see around 350 psi. That is front and rear charge pressure. If not charge pressure it’s the coupler. Like said above implement pump runs off from cover. Pull the cover and boot off the drive joystick. Had one rub the wires into and gave exact symptoms of a bad coupler. Make sure you have good working gauges when checking for pressure or it can Lead you down a bad path.
    DMiller and Ronsii like this.
  12. Nige
    Nige Senior Member
    14,583
    See post #11 above and follow it to the letter.
    I PM'd you the appropriate electrical schematic.
    DMiller likes this.
  13. Tyler d4c
    Mar 3, 2016
    254
    Salix Pa
    Small side note you may have to hook up the test lines on this 5g I have apart some are disconnected and capped so make sure there hooked up
    DMiller likes this.
  14. Nige
    Nige Senior Member
    14,583
    +1. Why disconnect a leaking test line when you could probably fix it just as easily.?
    DMiller likes this.
  15. RTSmith
    RTSmith Senior Member
    Oct 23, 2008
    359
    Amateur demolition & dirt pusher
    Middle Tenn.
    I have also seen this same set of symptoms when a rat or squirrel chewed through some of my wiring harness......
  16. Tyler d4c
    Mar 3, 2016
    254
    Salix Pa
    No clue that's how it was when it showed up here
