I'm trying to repair the steering clutch on a D3B dozer, but struggling to get it out. I've removed the bolts on both the power side and the drum side as well as all the linkage for the clutch and the brake, but it seems like the assembly is wedged between the two sides. On my D5, the drum will slide inward once loose giving a little more room to lift it out. I haven't got too rough with it yet, but should the drum slide in or is there some other trick to free up the assembly? Also, do I have to remove the brake bracket bolted to the front bottom?
Thanks for any help,
Ross
Ross
