Anyone on here familiar with that engine?
It's a 4.5" bore so more like a 3308 that wasn't.Was it moreless the 3408 predecessor?
The D346 is a 5.4" bore V-8 overhead cam.Was it moreless the 3408 predecessor?
And with all those gears and cams I imagine it was not cheep to build. Also as I recall at idle it made all kinds of rattling noises. Separate intake and exhaust cams so every time the lobes for one cylinder went past full open the cam followers would snap the cam it the direction to take up the back lash in the straight cut gear train.Very few were sold for on highway, had to be a fuel guzzling engine. Too many moving parts.
More than a 2 stroke Detroit?Too many moving parts
twin gear trains.More than a 2 stroke Detroit?
That is correct and I have two 1693TA/D343 engines. They have a sound of their own at idle.And with all those gears and cams I imagine it was not cheep to build. Also as I recall at idle it made all kinds of rattling noises. Separate intake and exhaust cams so every time the lobes for one cylinder went past full open the cam followers would snap the cam it the direction to take up the back lash in the straight cut gear train.
There was also a 5.4 bore 4 cylinder inline "D340?" engine that was the same with the snappy clattering noise at idle. I believe the six cylinder truck engine version was a 1693 if memory is working the version used in off highway equipment was call the D343.
Yep! Worked on many for those in the 988 Front end loaders before they came out with the 988B which had the 3408 V8The D343 was a 6 cylinder double over head cam.
The 5.4" x 6.5" engines.That
