Does any other manufacturer use Cat skidsteer controls in their equipment? Just curious.
we are already confusing pilot controls with electric controls.
"Pilot" controls means that your input (when you move the controller with your hand, foot, or whatever) goes into a system that operates the valves that, in turn, make your machine function. In other words it's a "control" system that is the "go between" between you and the machine. Most full sized equipment still employ hydraulic pilot control systems (hydraulic over hydraulic). The newer compact equipment has gone to electric pilot control (electric over hydraulic or "fly by wire") and I would imagine that all equipment is moving in that direction. I prefer the hydraulic pilot controls because I think they offer better feedback than fly by wire does.Aren't "pilot controls" the actual use of electric joysticks, and ISO is the pattern (one stick drives, the other runs boom) or am i way off?
DGODGR.
The pattern as a operator point of view. When someone asks what do you run, cat controls, bobcat, hand or foot, for example. I was curious how many other machines have adopted Cats's pattern as it were. I just started running a Case 430, it sure is very different from running Caterpillar skidsteers which is what I'm used too.
except for john deere, they know thats the only way they can keep charging exorbitant prices for their tractors.
