Serial # DJM00485
The battery is being drained of power when the master switch is left on. I do have a electrical schematic and have been trying to trace down the problem and I believe I have narrowed it down to a particular circuit, but I'm not positive yet. I disconnected the switch side of the ground cables from the master switch leaving the battery side connected. I have system voltage at every ground location but no amps so nothing is burning. I have taken a pic of a particular part of the schematic.....
If you can blow this up a bit, you will see the ECM circuit breaker on the right side of the page at square G12. If I remove the distribution side of the circuit breaker that feeds the battery power to the ECM my voltage drain stops and drops to .03.
I have checked the alternator and the starter motor and have found no issue with those.
My question for product support was going to be........is it possible for a small ground short inside the ECM that would not effect its operation and display no faults? Also......could it be possible for the switched ignition for the ECM to stay on even though the machine shuts down and has no display?
The ECM is stuck behind the engine against the firewall with almost no access or some of these questions I could answer myself. As you can see, it will take one of the Olympian Midget Contortionists with 5 foot long arms and eyes in their fingers to get to it.
No other circuit have I found that will kill the power draw other than this ECM circuit. Any suggestions, or experiences with this type of thing?
Yeah...........
........NO ACCESS AT ALL.
Yeah...........
