Cat977
Can I put a track chain/rail from a 977L 11K4042 into my 977L 11K5251? Also I read you can push the track adjusts all the way back and remove the the track without removing the master pin and braking the chain. I live about where the the glacier stopped in south center Wisconsin. Dug the house into the northeast corner of our hilltop. Put in geothermal in the valleyish place 500 feet below our house. Well it made the excuse to buy the 1972 Cat 225 excavator and the 1969 Cat 977K. I worked the 977L till it whore through the bushings, Quite aways though the pins lucky the track only broke though one side I run her up every couple of months nice and hot and go back and forth on level ground and mix up all that oil. The L has a 4 in 1. I want to dig a bunch more lime stone to use on forest roads.
I sure like reading the posts!
