Hello,
we are looking at potentially buying two Cat 977Ls - one serial is 11K05182 and I cannot find the serial on the other although I am sure it is similar.
long story short we don’t know the story and we know nothing about these larger CATs. One machine fired on ether but as soon as we got it to fire a little it started pouring fuel out of what seems to be a weep hole out of the transfer pump? It’s just a line that runs into the belly pan. Am I correct in assuming it’s a weep hole and is there no fuel return from the pump area on this system? All I can see is the fuel line incoming from the tank nothing else. It was smoking, I’m assuming it is getting fuel and is a runner we just didn’t have the best batteries and didn’t know what to think when it started dumping fuel.
For the sake of seeing if it will run, move forward and backward and steer, I think I will just run this line into the tank or a catch and let it bleed for the few minutes we run it.
Lastly, what else do we need to look for if I may ask? The other machine is seized but being able to buy them both makes me comfortable that I will have parts to keep the one good one running. I will check the fluids, try and check operation etc. but if anyone has some advice I am all ears!
also, what manuals would you recommend I get? I have been trying to download a nice service manual so I can look at the fuel system schematic and diagrams of the fuel pump but I think I will have to order a hard copy somewhere.
Thanks!! Tyler
Thanks!! Tyler
