CAT 963 VS Deere 755
Discussion in 'Track Loaders' started by roysbigtoys, Mar 7, 2018.
  1. roysbigtoys
    roysbigtoys Active Member
    May 1, 2010
    35
    Excavating Contractor
    Spring Hill ,Ks
    I would appreciate anyone's opinion that has run these machines. I am looking to buy my first track loader. I have ran a few 963B's and a 963C ( and that is probably what I will buy ), but have not tried out a Deere 755. What are the pro's and con's of each machine? Which one is the least expensive to own?
  2. DMiller
    DMiller Senior Member
    Feb 22, 2010
    3,569
    Retired
    Deere is as expensive to repair and a taste harder to find parts for the older units. Deere does not hold its value as well as a Cat, and as I have run both a 953B and a 755 trying them out would rather be on the Cat.
  3. hvy 1ton
    hvy 1ton Senior Member
    Jul 24, 2006
    1,519
    Lawrence, KS
    Everything before the 755K was built by Liebherr and with the partnership mostly, if not completely, dead parts might become an adventure.
    DMiller likes this.
  4. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    1,411
    Original 755 and 755B, 655B and 855, 855B models were Deere designed and built. I think the liebherr machines may have started with the C models. I did a lot of welding on my former neighbors 755 used for demolition.
  5. DMiller
    Feb 22, 2010
    3,569
    Retired
    Problem lays with the drive pump/motor components, was explained by a local shop those too had Liebherr origins on the older machines for a long way back.
  6. roysbigtoys
    May 1, 2010
    35
    Spring Hill ,Ks
    Thanks for all of the info. I really like the looks of the 755D & K, but do not like the fact that they are probably not as good as the 963. A Deere salesman was telling me yesterday that somewhere back that the K's are now built in Iowa and are a all Deere machine. Does anyone know what year Deere starting building there own machines and what do you think of them since then?
  7. DMiller
    Feb 22, 2010
    3,569
    Retired
    I suspect 'Assembled' in Iowa, no doubt the hydro components are from overseas. Have not the pleasure nor pain of working a Deere recently beyond an old 555G.
  8. mikebramel
    mikebramel Senior Member
    Jul 16, 2012
    1,350
    milwaukee
    Deere probably has Danfoss pump/motors which are easier to get parts for than Cat. Old Deere herr had Linde, which are top units.... assuming they aren't ran dry or overheated
  9. hvy 1ton
    Jul 24, 2006
    1,519
    Lawrence, KS
    All K loaders are designed/built by Deere starting with the 605K in 2011ish, larger machines maybe 2014. There are a couple 755K's around here. I don't know anything other than they haven't been traded off for 963's.
    DMiller likes this.
  10. SVTSHELBYGT500
    SVTSHELBYGT500 Well-Known Member
    Sep 12, 2010
    65
    Excavating Contractor 30 + Yrs.
    Pa
    Local cat dealer delivered a new 953 d . This about 2 years ago . Used it for few days and liked it alot . My local Deere dealer took me to coal valley , Deere demo area . Run a 655k for 3 hours was Soo impressed the I ordered a new 655k and love it ! They are built in Iowa ! Unlike a lot of cat stuff . I know these aren't 963 & 755 but all built on same lines
    roysbigtoys and DMiller like this.
  11. roysbigtoys
    May 1, 2010
    35
    Spring Hill ,Ks
    Now you have me wondering what I am missing if I don't try out a 755K. What was it that was impressive? Please give me the good and the bad of your 665K. Like you said I think the 655K and the 755K would be similar.
  12. SVTSHELBYGT500
    Sep 12, 2010
    65
    Pa
    When I compared cats model was 953d . They used a single tank for hyd system and travel system . If you have a component failure u got a real problem . 655k uses 2 separate systems . Cat has had failure . Drive components for 655 k is sized same as 750k dozer . 755 k sized as 855k dozer . These components are pretty much bullet proof . Check it out . For the amount of money your going to spend I would demo both !
  13. roysbigtoys
    May 1, 2010
    35
    Spring Hill ,Ks
    Well I could not find a 755K any where near me to try out and ended up buying a 2006 model 963C with 8700 hrs. I haven't got to use it much with periods of rain for the last 2 weeks. So far I am real happy with it. Maybe when it comes time to up grade there will be a 755 in the area to try out.
    Thanks for all the input from everyone,
    Happy Easter
    DMiller likes this.
  14. DMiller
    Feb 22, 2010
    3,569
    Retired
    Saw a new 953K the other day, ugly little machine. All the tins had been restyled, looks more like a Komatsu than a Cat. Asked the hauler about it, he had nothing good to say beyond the controls were easy to use.
