Cat 955k
Dparson4093
Georgia
I replaced the gasket on the bottom of the steering clutch case. In the process I broke the little copper tube that’s in front. Replaced it with a rubber tube and hose clamps. The machine was working fine before now no steering at all and the pedals are very weak. I’ve adjusted pedals. Please help
See if your repair hose failed. I had a JD loader somebody replaced a hose with rad. hose and it just swelled up and burst over time. It was a special type of hose you had to get from JD cut to size. I think it was partially silicon hose. You may need to replace the copper tube though.
