Cat 955k won’t start
Plambert
Georgia
Hello,
I’ve been through just about every related post on 955k starting issues and am not sure what the pursue next.
A couple months ago it was running strong then all of a sudden puffed some black smoke and slowly died. I suspect it could have been bad fuel. Couldn’t get it to start back.
So far I’ve drained the tank and changed all filters. Changed out the transfer pump and all injectors. The injectors were full of junk when I swapped those out.
I’m pretty sure I’ve got all the air out of the system. But I’m noticing I’m not getting much pressure at the injector line when I crank it and crack the injector lines but there seems to be plenty of volume. Any suggestions on where to go next?
thanks
hector gemme
Ste-Julie
We bought a 955 many years pass with brinth new motor with new big air filter and small air filter was like new the motor was starting but not easy and was smoking and maybe 30hours working the motor died and the probleme was the small air filter you could removed the 2 air filter and try to start with no air filter now am going to slepped.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
I wish EVERY diagnostic thread started with.. REMOVE THE AIR CLEANERS..
I can’t count the number of times I’ve made a service call for a “NO START” condition, only to find the air filters packed full of crud..
I take’m out, throw them on the ground and watch a dust cloud like I let off a nuke.!! Lol
Then of course comes the 30 minutes of bleeding the air out of the system..
Plambert
Georgia
I was assuming it was fuel related since I’m not getting any kind of white smoke while cranking. Previously when I bled the air out the fuel system the fuel when cracking the injectors lines would shoot out 6–7 inches when cranking now it’s more of a dribble out of each of the lines.
I’ll try taking the pre-cleaner and air filter out and report back. Thanks
hector gemme
Ste-Julie
If you have no white smoke when you starting with trottle on or off with the fuel tank cop loosed and if you are missing fuel you could disconnect the rear fuel line from the tank if you have full fuel and if fuel is oké disconnect the front fuel line and put air in if the line is plugged
Plambert
Georgia
I’m getting good fuel flow when unscrewing the bleeder valve on top of the secondary filter housing. Seems to be getting good flow up to the injectors. The fuel doesn’t seem to be building much pressure in both the throttle off or on position. Are there any tell tell signs the injection pump has failed ?
I’m gonna try removing the air filter to rule that out when weather permits.
Does your machine have a lift kickoff that could be engaged? I drove my former neighbors 955K a couple times and it wouldn't start 1 time because the loader valve was engaged.
d9gdon
central texas
You have to have oil pressure on some models before your injection pump will allow any fuel injection pressure for starting. There is a fuel stop that has to be overcome by oil pressure in the injector pump.
Have you got good oil pressure when cranking over?
d9gdon
central texas
You do not have proper fuel flow if that's all you're getting. Which injector pump do you have on there, or what is the serial number of the machine?
If the flow is restricted, it could be air locked. That's what it sounds like to me. Did you look for an inline fuel filter between the tank and the lift pump that could be plugged?
d9gdon
central texas
OK, first thing I can think of after looking at an 85J model online is the primer pump...they're notorious for sucking air. The o-rings inside them get worn out and air can be allowed in. You can rebuild them easily.
Have you pumped it up with the primer pump? Does it pump up and get really hard to pump or does it bypass when you do it?
Plambert
Georgia
I actually just put a primer pump back on it. Someone who owned it previously took the pump and lines off and plugged the holes. I may have some air trapped in it somewhere because it never really gets firm.
Plambert
Georgia
Yes looks identical to the picture you posted.
