To answer donkey doctor, as you can see in the picture of the air tree, any exposed piping is 1/2 galvanized metal pipe. The pvc pipe runs overhead and is cradled inside of C channel for the entire run across the shop. All of the drops are galvanized metal fastened to the walls. osha rules would not apply as this is my private shop for my own use. Thanks for the input, I have never seen the regulation before. I guess that they could cite me for general stupidity and probably would if they watched my work methods for a little while. Who in this forum could pass their scrutiny?
"To answer ih100. As luck would have it, the new track pads now measure 77" outside to outside of the track chains. The bucket measures 78" wide. The cost to sheer both sides of the pad would have been double the price in labor cost. I can use the extra floatation as, come spring, I will drain and clean out my 1 1/2 acre lake. It will be pure mud, but it does have a solid rock bottom underneath all of that muck. I do have a Cat D4E with a winch for plan B if needed.
You also have to consider, those new pads came with the loader when I purchased it and they were delivered to me. That set of pads cost about half of what I paid for the machine. Cat priced the new bolts and nuts at more than $900.00. I paid $237.00 for 312 bolts and the nuts and they are genuine caterpillar parts. As you can tell in the pictures the old pads are worn and they are all breaking on the leading edges.
True,the track chain shows some wear. It measures out at 7" 1/16. The rails are decent and the sprockets show considerable wear, All bottom rollers are good to go and I am replacing 1 carrier roller. Front Idlers are good shape. It is a farm machine and it does not have to earn its keep any more. It is basically retired and so am I. You could go hog wild if you were rich and turn the pins and bushings and at the same time replace the sprockets. I chose to keep her going and run till destruction. You never know what will give trouble next but I would hate to know that I had to sit in that seat and operate it until it destructed before I could quit.
I think that those old cats are grand old machines and I feel honored to own them. I am just as content to work on them as I am to operate them. If they didn't need a lot of work done on them I couldn't afford to own them. They are both 1978 models and I had to wait 35 years for someone to wear them out so I could afford them.
The bright side of the picture is when I get all of those parts replaced imagine how much scrap metal I will have to sell and recover some of the cost.
As someone who has worked hard all of my life, I do feel for the guys who post on this forum with major breakdowns and problems, as their machines do still have to earn their keep and turn a profit. From those noble and knowledgeable people is where I learn to tinker on my own junk.
