As I said before, you don't need to make a box initially. All you need is 2 lengths of wire and 3 Deutsch terminal sockets. Click the link in Post #19 above, it will take you straight to it.
we took off the outer and inner filter to make use we are not starving air sir.Have you changed the inner and outer air filter since being in flood?
To make myself clear sir, you mean turbo boost pressure and fuel pressure can you throw me some specs what i'm suppose to get? thanksYou will need to check fuel pressure and boost pressure next.
You could also inspect the turbo for wheel or housing damage or interference.
I understand what you're saying, and it may be only a remote chance but did you remove EVERY pipe fitting, elbow, etc, etc, in addition to the fuel supply/return hoses just to make sure that none of them was obstructed.? For example, did you completely disassemble the head assembly of the secondary fuel filter, or remove the injectors and clean out the fuel passages in the cylinder head.? What complicates everything in this particular machine is the fact that it was flooded, and it is essential to remove even the remotest possibility that water or anything else got to places that it shouldn't have got into.Good day sir, before i made this post we already cleaned out all possible dirt and water in all the fuel system lines including, replacing filters and etc.
There is nothing mentioned, and it is not usual on this type of system. If you cannot see anything then I would think that there isn't one.One more question sir, are any strainer along the fuel lines from secondary fuel filter before going to injectors. thanks
