Liviu Popescu
Hi Nige, all,
Just trying to figure out a way of attacking this tomorrow. Where we work in the quarry there is no cell coverage so I only find out stuff once the operators return at the end of the shift. Hence, whenever I ask them to check something, I try to think of all the possibilities and get the most out of the day/shift (as it will take another 24h until I get a chance to try another thing).
My main concern is that the both the parking brake and low brake pressure alert lights are on, as in the picture which I shared earlier. Also, I’ve taken into account the fact that the machine braked itself. Looking at an extract from System Operations for the 5SK743-UP, I see the following statement: “Loss of brake oil pressure will cause both brake oil pressure alert indicator (3) and action light (2) to flash. The action alarm will also sound if the engine is running. The parking and secondary brake will automatically engage when oil pressure drops below 6035 ± 515 kPa (875 ± 75 psi).” Now, our action light has never worked but all the alerts do function. So taking into account that the low brake pressure light is on, parking brake light is on and the machine braked itself, I can only assume the oil pressure dropped below 875psi.
I will assume that the pump is not the cause of this, as this would probably be the most expensive part and worth keeping for last resort.
Following the hydraulic oil route:
1. From the pilot pump, oil flows into the accumulator charging valve where it acts against a relief valve which limits brake oil pressure at 2400 psi. Could it be that this relief valve is stuck open? I don’t see what else would be causing such a brake failure taking into account that the accumulators were empty before charging last week and everything did work, except for the strange noise. Maybe the noise I was hearing was this relief valve on its way out.
2. From there is flows into the valve that control the accumulator charging. When it reaches 2100 psi then oil flows into the tank and the accumulators are charged.
3. When accumulator pressure drops to 1700 psi then oil flows again into the accumulator and charges it to the pressure at point 2.
For points 2 & 3, if the parking brake engages by itself then we’re not even at these pressures so it would all go back to either the relief valve or the pilot pump.
We will put a pressure gauge on the brake system, presumably at the port on the accumulator charging valve, and if by some miracle the pressure is above 875 psi and around what Nige suggested 1700-2100 then my logic would tell me that the pressure sensor on the accumulator failed and at the same time the bell-crank spool on the parking brake valve. This is probably highly unlikely but could be.
Is my logic flawed or any points worth adding? I’ve dreaded getting involved in hydraulics and was lucky enough not to have any issues so far but it seems I’m forced to take a leap of faith.
I refuse to believe that by charging the accumulators we somehow broke something, however if the accumulators were over-charged would it cause any behaviour as such – but again how would they?
Lastly any suggestions on the panel with the action alert towards the right of our CMS? It never works as you can see in the picture.
I really hope this helps others as well which are new to this as me.
Thanks,
Liviu
Thanks,
Liviu
