Cat 943
What oil should be in the shaft? Looks like whoever had it before me replaced the oil with a lot of grease
For your climate SAE50 TO-4 oil, the same as what's used in the final drives. The original manual recommended TO-2 oil, but that specification has now been replaced by TO-4.
Don't you have an O&M Manual.? They come in pretty handy and aren't expensive, maybe $50 to download one from Cat.
Cheap "old" Geezer
Was thinking on this where Maye need do Both sides and make certain the bolting faces are as flat as possible.
orangepeanut
south carolina
I don't have a manual yet but I will be getting one soon. We ended up getting it put back together. Teardown to completion took us 3 hours so it went surprisingly well and everything looked good. I appreciate all of y'all's help.
oarwhat
buffalo,n.y.
img_20230221_094614-jpg.280749
It sure looks like the track frame has a crack in it in this picture. Just below the pivot pin.
orangepeanut
south carolina
Everything has been working good on it. Until I noticed a slight coolant leak, then I check it and find oil in the coolant. Not sure exactly where it's coming from, doesn't seem to loose any hydraulic, transmission or engine oil. I guess I'll be trying to figure this one out in the coming days.
Dave Neubert
Monroe NC
Looks like just the bolts are broken remove track frame take pivot off and remove broken bolts you can then check pivot for wear it is just 2 bushings and a seal
