charles walton
Cat977, do you know of any good tricks for this problem?
I pulled it back apart and found that one of the rollers on the pinion bearing inside the case had dropped down and hung up on the race on the end of the pinion shaft and it damaged it oh so slightly!!! I'm going to have to completly disassemble everything to replace the bearing now. All of this happened with grease packed into the bearing so maybe there was more wear than I thought to allow the roller to drop down.With assemblies in general things should go together fairly easy. When it doesn't most of the time you will need to pull it apart to find out why. You may have damaged the shaft and bore if you pulled too hard on a dry assembly that wasn't going in straight. Did you lubricate the cross shaft? I would use super lube grease on the shaft and bore on the finale. In the picture it looks like there's a good ways to go yet. I would try backing the bolts up till you can rotate the sprocket. I bet you need to release the clutch. "REMEMBER I HAVEN'T DONE THIS JOB BEFORE." I would think it could be wiggled because of the clearance between the gears. Measure the gap between the finial drive casing and the main frame all the way around. Then tighten the bolts by the biggest gap while wiggling. Give a holler on how its going.
I got the assembly apart and replaced the bearing with a new aftermarket bearing. I was expecting a Chinese knock off but it turned out to be a Bower USA bearing which is exactly what the OEM part is. Got it all back together and installed, now I'm working on the roller frame.Just a bit more on this subject. I use homemade guide pins a lot. Cut the heads off a couple bolts. Sometimes long, sometimes so short you need to grind a couple flats on the tip and use a needle nose pliers to get them out. I make them different lengths so you can get one started and then try for the other. Point them on the lathe or grind them. Then have the top tipped back to help cancel out the work of gravity. Have a Nice cold Beer when Done !!!
Best of Luck
Been a busy fall and winter but now with bear,hog and deer season over I can get back to posting about my progress on the loader. I got the left side all back together and used it for a few minutes to take out three big oaks that were in the way of my kennel expansion.Now I have the right side torn down and working on it. No duo-cone leaks on this side so I'm not going as deep on this final.View attachment 251643 View attachment 251643 View attachment 251643Its good to see things coming together for you!
Well, I decided to take a look and it seems I will have to replace the hub and possibly bearings on this side too.What’s the latest on the crawler?
Thanks for the encouragement,I was thinking about honing the rough spots but I just wasn't sure. I did not want to tackle the job of changing the pinion.Doesn't look too bad to me Charles, you aren't going to the races. Take a small stone or burr on a Dremel tool and grind out any sharp edges in the pits. They can start cracks to get more flaking or even chipping stay off the tooth face. If there's rough spots on the face of the tooth buy a new very hard and smooth honing stone and smooth them up. You did the other side this should be a brezzzzz.
