If you use Loctite 660 it will only dry if the parts are .5mm max. gap. In air it won't dry. I'd guess 2 tubes would be enough and I'd put it on both pieces after making sure they are spotlessly clean. I wouldn't use primer because it lesions the strength. You could use some heat to help it cure faster though. Even a little heater with a tarp to contain the heat would work for a couple hours. A little warm to the touch is all you need and then let it sit another 24 hours to fully cure and have the most strength.
