On June 12 I think I thought there was supposed to be a picture of the 2 together but I never saw a picture. Bob's right about the need to press them together. The Loctite can help to hold them together and fill up any gaps. On straight splines the Locktite probably would hold fine, depending.... On a taper it wants to come apart. In a way you are expanding the sprocket and shrinking the hub. Think of it like wood and glue the glue won't work without a tight joint. If you put Locktite on the pieces, the pieces might not even touch each other. You "Need" to press them together to squeeze out the excess Locktite, almost like gluing 2 boards together using clamps. But you need to go even further. You need the hub and the sprocket to always clamp each other together. Wood has pores/grain/imperfections/growth rings for the glue to mate them together. When the glue drys you can take the clamps off, jobs done. Steel has micro pores, ect.....,but not enough. You have to leave the clamps on, or the Locktite won't help you. Changes of temperature, fibration, running back and forth will cause the tapered splines to loosen up. Once they loosen even a little the whole thing is loose. That is not true for a straight shaft. I have to go right now but I thought I was thinking before about using your jack to put it back together.
