charles walton
I have already ordered a 50 ml. bottle of Locktite 638,I picked it because of the tensile strengyh being the highest of 4500 psi. Is the primer compatible with it and is 50 ml. enough do you think?Did some talking with my old Locktite rep. With the beating going to those splines go with High strength large gap 680 retainer compound would be best. Heating to 400F will break it apart latter. If I used a primer (I would in this case for sure) the only 2 in the toolbox. My chose for this. SF 7649 N, 30 min. assembly time, slower cure time. Tougher with the slower cure. (SF 7471 T 25 min A.T. faster cure time, can fill bigger gaps. "" Do Not Use on Warm Parts Sets Up Real Fast ""). It would be a good idea to do the job on a cool day it will give more assembly time. Check back for more if you want to do it.
Best of Luck
