Nick & Pat
throttle control will not pull back beyond half way point.
linkage is working properly and has full, smooth range when disconnected from governor
opened governor compartment and slotted pin moves freely when pushed down by oil pressure from the top oil line but seems to not engage with rotating portion when trying to move throttle into wide open position properly
oil and filter changed so it should not have anything to do with the travel of internal workings
when problem first started, oil pressure pushed oil from front oil seal
thought it was the seal, i changed it but still continued to leak even more
seems to be a lot of pressure building up in governor
