Jonathan Wurz
Shifting from F to R it will jerk forward before moving in reverse and vice versa, when shifting F-N-F it will jerk forward, pause then move forward. If I leave it in neutral for 5-10sec then change direction, it will shift without the jerk. Shifting between gears is very rough except for the 4th gear which is very smooth. It gets worse as transmission oil gets hotter.
While the oil is cold, shifting is perfect. Even high speed directional changes are very smooth. I do have some more info
but but I'm not sure what's relevant and what isn't. 1999 4YS01211
