Cat 931B cummins engine swap
Discussion in 'Track Loaders' started by magnagreg, Feb 14, 2020.
  1. magnagreg
    magnagreg New Member
    Sep 11, 2019
    1
    central virginia
    Bought a Cat loader with a hole thru the block... did a little research on block/engine availability before hand. Price wise, it would be pointless to spend the amount the dozer is worth trying to replace with a OE cat 3204.. I HAVE purchased a 4BT and will need some machining on the bell housing, flywheel, and crank adapter to make it work with 3F/3R transmission. ANY Recommendations? any body know how the youtube guy "labrador iron" is to work with or how I might get in touch with him? He posted several videos on machine work involved .. he did have a video posted of tractor running afterwards but didnt go anyfurther on "follow up" year later videos..
  2. Joe Fick
    Joe Fick Well-Known Member
    Jul 27, 2017
    87
    65459
    Wouldn't it be better if you bought an engine from a salvage yard. Cat and Cummins are 2 very different engines. Yes it can be done but the results may not be worth it. I'm guessing the 4bt Cummins is a smaller moter than the 3204
    DMiller likes this.
  3. Fat Dan
    Fat Dan Well-Known Member
    Jan 14, 2020
    80
    Alaska
    I'm with Joe on this one even if they have equal hp. I put a ford engine in an International for a friend it worked but not like it did in my mind. The parts I had to manufacture was a daunting experience I wish never to encounter any time soon. :mad: The the gearing between the trans and ring n pinion were not very compatible. It seemed to me there were thousands of tiny little problems that would pop up and take many hours to cobble together. So if your time working the vehicle is worth it by all means slap er together but if your time is worth anything add that to the total price tag. I think you would come out ahead of the game, both in time and money, if you put in an engine that is comparable.
    Either way good luck.
    Fat Dan
    DMiller and Joe Fick like this.
  4. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    3,794
    I'm curious how you would drive the hyd. pump since it runs off the timing gears.
    DMiller and Fat Dan like this.
  5. Fat Dan
    Jan 14, 2020
    80
    Alaska
    He may have realized his project was too daunting.
    DMiller likes this.
  6. kshansen
    kshansen Senior Member
    Mar 11, 2012
    7,986
    Central New York, USA
    Thing I see with these kind of projects is that if you have the tooling and skills to do all the machining and fabricating yourself you might end up with a working machine at a reasonable cost.
    But if you have to pay a machinist to make adapters and they also have to design the adapter the cost will spiral out of control in no time. Just modifying the coolant lines could cost a pretty penny. Also does the engine have coolers that can adequately handle the needs of the 931B? Is the 4BT engine oil system configured to handle the demads of this 931B, I mean the conditions a 931B may be used under might be very different than the 4BT was built to be used.
    Basic things like is the flywheel housing of the Cummins designed for a "wet flywheel"? Are both engines running the same SAE size flywheel housings? Just looking at the displacement of the two 3204 5.2 liters and 4BT 3.9 liters has me wondering if the 4BT would have the torque output needed, could not find those spec's real easy online but still have to wonder.
    DMiller, Nige, RZucker and 1 other person like this.
  7. DB2
    DB2 Senior Member
    Jan 4, 2015
    453
    Winnipeg MB Canada
    We had 4BT’s that had a hydraulic pump drive under the injection pump. The OEM ran a big Cessna style gear pump and a smaller back to back steering pump. I still have at least one. I’ll take a picture if anyone wants to see.
    DMiller likes this.
  8. charles walton
    charles walton Well-Known Member
    Nov 25, 2012
    190
    Etowah Tennessee
    I think that even if he makes it work it will be VERY underpowered.
    DMiller likes this.
  9. Tyler d4c
    Tyler d4c Well-Known Member
    Mar 3, 2016
    247
    Salix Pa
    There's a 931 with good engine for sale cheap he needs it it's in Gettysburg pa
    Fat Dan likes this.
