Aaron McGrew
No turn to the right,
Got rt clutch assembly out, found slave cyl. Piston and push rod laying in the bottom, explains no turn scenario. That bay was full of hydraulic fluid from blown slave cyl.
Brake looks new but has been soaked with hydraulic fluid? Replace or not?
I know how to redo brake pads from doing airplanes, who sells new liners?
Bearing is done in rt side so back to cat for that!
Pulling lt side while in there to look at it!
Anyone know what thickness a new pad is so I know whether or not to replace lt brake!
Thanks in advance!
Thanks in advance!
