I sent you a message.
I also have a 2007 725 with the same shifting problem has first and reverse shows shifting into second but doesn't shiftI sent you a message.
Does the lockup clutch engage.? You should be able to feel it engage if nothing else. If you didn't know better you'd think it was shifting a gear.I also have a 2007 725 with the same shifting problem has first and reverse shows shifting into second but doesn't shift
Could you resend please i did not get itI also have a 2007 725 with the same shifting problem has first and reverse shows shifting into second but doesn't shift
B1L01450Does the lockup clutch engage.? You should be able to feel it engage if nothing else. If you didn't know better you'd think it was shifting a gear.
We ran the transmission fill calibration and at the end it says calibration unsuccessfulDoes the lockup clutch engage.? You should be able to feel it engage if nothing else. If you didn't know better you'd think it was shifting a gear.
Right now only active code is 96-3 fuel level sensor above normalIf you tried to calibrate the transmission clutch fill you obviously have (or have access to) Cat ET. What Diagnostic Codes are logged/active in the machine at the present time.?
BTW the message referred to in post #41 was not for you, it was for the poster from post #40 on the previous page.
Yeah, I wrote it a bit tongue-in-cheeck just on the off-chance.No hills at all here
