Nik54
- Joined
- Feb 18, 2019
- Messages
- 10
- Occupation
- Auto-electrician
Good day to all,
I have problem with CAT 725 which is converted to water bowser.It worked like that for quite while,since new owner bought it,it came out from low bed in reverse,but that was last time,now it is refusing to go to reverse.Comand is accepted,reverse alarm is on,display indicator is showing R,but machine does not move.Forward is moving.Confusing thing for me is the red bucket light on the dash,according to service manual is ON when hoist lever is not in floating position.Since I could not find proper operators manual to read proper handling of the hoist lever,I think signal which keep the light ON is avoiding activation of reverse solenoid.But I am just guessing.Does anyone knows something more about hoist lever operation.I tried to move in all positions,light does not go OFF,signal wire is changing the value when you move it trough all positions.On the display there is only code E329,which is according to the manual clogged transmission filter.
Many thanx in advance
Nik
Nik
