Rocket Man
Hello all. Back again with an issue i can not seem to figure out. This is on my 1987 Cat 426 Backhoe sn 7BC00580. The starter just would not engage, Stuck right in the middle of my driveway and it dies and when i tried to start it it was a no go. Turns out it was out of fuel even tho it had 1/4 tank. Down pipe must have a hole in it.
Anyway, as i was trying to start it i let up on key and it just kept trying to start on its own. The solenoid would not disengage for some reason. I was able to unhook the battery very fast, i keep tools handy for that reason.
So i took starter off and removed the solenoid as i was going to get a new one. As a removed the solenoid the plunger part stayed attached to the fork. I thought that was ok as most i worked on had a pin that kept them in place. I rotated the starter and that plunger just fell out. Now that plunger fits into the solenoid housing which has a fixed stud that the plunger fits over. Inside the plunger is a spring that presses against the fixed stud.
Upon closer inspection i discovered that there is a little spring in the plunger that was distorted and prevented the plunger from moving in or out.
As a result i got a new solenoid and reassembled. However, doing the bench test i discovered that the solenoid would not push the fork out enough for the starter drive to engage the flywheel.
So here is the question, how does that plunger fit to the fork/lever? When i put it back together i figured it just fit up against the fork and was held in place by pressure. Now i am wondering if maybe it somehow hooks over the fork? It does have this weird looking spring loaded slot at the end of it.
Anyway, sorry for long post but better to have full details. Anyway help is appreciated.
