Cat420
- Joined
- Oct 11, 2004
- Messages
- 527
- Location
- Pine Bush Ny
- Occupation
- Construction, small engine and machine shop work
It will dig out stumps are good or better than any other backhoe. The lifting power of the backhoe end is limited by stability first. What that means is you can pick up enough weight to lift the front end up or fill the front bucket with dirt and get more lift farther out. Some machines are hydraulically limited, meaning you run out of power before lifting the other end. With the bucket filled, I can dig stumps out almost as far as it will reach. Obviously different trees have differing root systems, so some are easier than others.
We have no A/C, so summers are a little warm, but the heat works fine in the winter.
I should also note, it is one heavy beast. Ours with the e-stick, heavy counterweight up front, 4n1 bucket, cab, drive shaft guards, and stabilizer cylinder guards weighs in right at 20,000lbs. Needless to say, mud is not its friend. Not that a 16k lb Cat, Case or Deere will be a whole lot better, but more weight never helps.
