jmtrackworks
- Joined
- Mar 7, 2011
- Messages
- 35
- Location
- South Carolina
- Occupation
- Owner/Operater; Martins Track Works
I have a 2000 cat 416c backhoe that has a large transmission leak. It is leaking fluid from the bell housing assess hole where you assess the Torque converter bolts. My brother and I removed the trans. and replaced the transmission input seal (oil pump seal) and the large flat o-ring behind the front plate of the pump. Reinstalled the trans, replaced fluid and started the engine, it took about 10 seconds and it was leaking again just as bad. Other than damaging the seal or o-ring during installation, does any one have any throughts or ideas on the continued leak.
Signed,
One defeated man!
Signed,
One defeated man!
