DirtyHands
The steering cylinder is leaking on my Cat 416C backhoe (serial # 1wr09267). What is the removal procedure? I will attach some pics if I can.
Another question - what is the purpose of the solenoids located at the bottom of the front loader control valve body. Looks like mine was damaged before I bought it but it doesn't seem to affect the operation that I can tell. I noticed while I was underneath machine adjusting parking brake caliper. The two 1/4"x6" bolts were bent but I was able to remove it. Unfortunately the threaded piece connecting solenoid linkage to spool was broken and I can't easily get to it. The wires were pulled loose also.
Thanks in advance for any help. Much appreciated.
