funwithfuel
You need to measure fuel pressure full throttle under load. For example, raise the dump bed at relief to place some load on it. Idle doesn't really tell you anything.
Okay, I will try and get a loaded pressure reading. I wish I could raise my bed inside the shop, darn low ceilings.You need to measure fuel pressure full throttle under load. For example, raise the dump bed at relief to place some load on it. Idle doesn't really tell you anything.
Easiest way to get someone's attention on a thread is like this:Haha fair enough, well thank you for all of your help so far funwithfuel, I really appreciate it! I will try and get in contact with thepumpguysc and see where he leads me. It's been a great learning opportunity thus far, if nothing else.
Thanks! I wondered how to do that lolEasiest way to get someone's attention on a thread is like this:
@thepumpguysc
@Cory W
Now it sends an alert to him that he was mentioned, and he'll probably come and see what was said.
So I wasn't able to remove it for inspection, but I was able to put air through it no problem. I also assumed it was clear after I pressurized the tank and had a solid stream of fuel out of the fuel line.BTW, how did the standpipe check out?
I just don't see it restarting and back to normal so quickly if it was a fuel restriction.
I like this condensed version, yeah that pretty much covers it. The only thing is once it starts to lose power, it will always die. It never picks back up until it quits and is restarted. I plan on road testing the truck today with my pressure gauge hooked up and see what fuel pressure does. I can duplicate the problem pretty well, bottom of seventh gear with heavy throttle almost always does it.So, standpipe is clean as a whistle. Running fuel pressure ~30psi @ idle. AFC diaphragm leaks oil in vacuum test. Fuel filters are clean and new. Pressurizing the fuel system with the return line dead-headed shows no leaks. Running @ 75% or more throttle, she bogs down to the point of dying but continues running. Have you checked fuel pressure at full throttle, loaded?
Most definitely, are you thinking fuel shutoff solenoid or air/fuel ratio control?It's almost like something that turns the fuel on and off is not working correctly.
