Cat 325BL: Educate me on a drifting swing system
Discussion in 'Excavators' started by LCA078, Oct 31, 2020.
  1. LCA078
    LCA078 Well-Known Member
    Sep 29, 2019
    224
    Austin, TX
    Never really noticed I had a problem with the swing until I was on a slope and saw the hoe would drift, or really free-swing, down hill when I was off the controls. On level ground it seems fine and appears to brake or slow down correctly during a full speed swing...but I'm not an experienced operator so maybe my 'fine' isn't really fine.
    I thought there was a swing brake or equivalent to prevent down-hill free-swing but have no idea where to start looking to troubleshoot. I assume it could be as simple as a bad electrical connection or some really expensive hydraulic issue.
    What ya'll recommend?
  2. DEMLONE70
    DEMLONE70 Senior Member
    Sep 30, 2012
    270
    Belgium
    Serial number ?
  3. John C.
    John C. Senior Member
    Jun 11, 2007
    11,541
    A lot of those machines had a soft swing function installed from the factory. Check all the rocker switches on the right side console. A serial number will allow some people here to look up what your machine originally had from the factory. As far as the swing brake goes, it is actually a swing parking brake. It is spring applied and hydraulic released and only applies about seven seconds after you stop operating everything.
  4. LCA078
    Sep 29, 2019
    224
    Austin, TX
    serial number in my signature but i'll add here too:
    Caterpillar 325BL Serial *2JR01724*
    John- Are you referring to the Fine Swing Control Rocker?
    I assume you're suggesting I keep this rocker off (pushed to the left)? I guess this is also where I get confused because I see swing brake and assume this is an immediate acting swing brake instead of the 7-second parking brake.
  5. Jam
    Jam Well-Known Member
    Nov 11, 2009
    209
    Building contractor
    Cork, Ireland
    You can check the swing brake by dropping the deadman while its on a slope starting to creep on its own and see does it stop abruptly. I had a b series years ago that two of the swing motor pistons poped off their slipper feet which cased it to free swing on a slope. New pistons and a cam plate sorted it out
  6. uffex
    uffex Senior Member
    Jan 23, 2012
    2,900
    Admin
    Lincoln UK
    Good day
    You may find the attached a useful starting point.
    Kind regards
    Uffex
