Shterion Kostov
Hi, Guys!
I have been having a lot of trouble with a CAT 320C Excavator (S/N BDE00683) with 16 000 hours on the clock, which my boss just bought. The excavator is well serviced, engine looks and works well, but when under load, the engine revs go down very fast, it stalls and there is no hydraulic power. I can excavate only with the tip of the bucket. If I try deeper, it stalls. It also happens with every other movement.
So with the help of some topics in this forum and a lot of reading in CAT SIS to understand how it works, I decided to check the Pressure reducing valve, which regulates the pumps' work. I thought, that under load, the PRV does not do it's work and so the engine looses revs and stalls. So I got a manometer and a multi-meter and I did a PRV Sweep test. I followed the instructions from CAT and I should have measured 0,2 to 0,75 Amperes at the Solenoid input and 4,8bar (70 psi) to 34,5 bar (500 psi) pressure at the tap. However, for the electricity I get 0,14 to 0,5 Amps and for the pressure I get 4bar (58 psi) to 22 bar (319 psi).
This result puzzles me, I really thought the PRV would simply be broken and I would replace it. I am thinking of calibration of the PRV, but the calibration lets you adjust by +/- 0,3 bar the low and high values and I am getting a much bigger difference in my Sweep test. I contacted the previous owner, I turns out the local CAT dealer did not manage to fix this issue in the past 4 years... I am really amazed.
Can you give me some advice on what to check? I am not looking for problems in the engine - it just looks perfect and the excavator was just serviced to 2000 Hours PM by the authorized dealer. I am not thinking about the throttle actuator, it works well I think. Also, the problem appears with every type of movement, if it was for a specific movement, I would see the appropriate valve in the main valve controller. I tried working in manual (backup mode), the problem is the same. I even unplugged the PRV, the problem was the same.
Thanks a lot, any advice will be of great help!
Greetings from Bulgaria!
