John C.
You should be able to see that on the monitor panel and know for sure how much. Your rebuilt engine may have more horsepower than it does cooling system. Maybe run a cycle time on the boom up function as well.
Yes you are correct about the cat caps . I plumbed in my cooling system pressurizer to the water manifold and built 4 psi and it leaked off quickly. Talked to the local cat house and they found where it said caps secondary relief is 12.5 psi , i managed to track down a carquest 13 psi cap and did same test was able to pump it up to about 14 psi and it bleed off to about 10 psi and was just barely seeping , installed new t-stat noticed a very different flow on warm up while i was topping of coolant it was cycling like an unloaded engine at idle should , when i turned of auto throttle and put it on 10 it opened and stayed flowing but seemed slower then before i think it may have been a defective t-stat after all. I stacked brush for about an hour stayyed 2 bars away from the red before it was touching the red about to yell at me . Need the guy to run it now what takes me an hour to oveheat took him 20 minutes so we shall see .How much is the RPM dropping when a load is applied? Should probably be no more that 150 with the throttle dial at 10 and say booming down swinging and stick out at the same time. That fact that coolant temp drops so fast indicates the cooling system is working correctly. All the Cat excavator radiator caps are junk. Go get a quality one at a Napa store somewhere.
T-stat has a hole in it it self bleeds rather well i did pull the fitting out of the water manifold just to be sure found no air. Said fitting is an original compucheck fitting for taking coolant sample or checkin pressure didnt want to disturb that one without a replacment on hand. Gonna see if cat house has a spec for waterpressure if there is i will check it .I would not disregard removing something below the thermostat to bleed air. Do not that that is your problem but it costs nothing.
Then I would plumb a gauge into the back of the oil cooler, block or head. What is your coolant pressure at full throttle?
