Pralhad Birdi
Hi all,
I've recently had a Cat 317 Serial No. 4M00179 come back from a site where it was stood idle for a couple of years.
Upon testing, we found it was struggling to lift the boom and extend the stick under no load at engine idle. With increased revs, it would do it, but slower than it should.
We cleaned out the tank, fuel lines, replaced all the fuel filters, got the injector pump and nozzles serviced. Now the engine runs a lot smoother, but it's still got the same issues.
On idling, all the operations are extremely slow, and when you put the boom down, it just stops there rather than causing the engine to shut off. It's the same for all the controls. I'm pretty sure it's a hydraulic issue, but I'm not really sure where to start. Any ideas?
