Cat 312B/C/D/E
dieseldog5.9
New Hampshire
Going to look at a 314D Tomorrow, has some traits of a zero swing machine but not totally zero swing, not 100% clear on that as of yet. Has a blade, never wanted a blade, thought those were for mini excavators so they didnt get drug around, but maybe there is some advantage that I am missing, being a mechanic the thought of running an excavator undercarriage back and forth makes my wallet tingle.
Does the blade have a cutting edge. If not, factor in a new bottom edge welding job every 500 to 1,000 hours.
Around here they use them like battering rams and full dozer blade to work on stumps, asphalt and concrete. It was a common problem with trade in machines. They were broke up at the push beam welds to the back of the blade and/or the bottom edge of the blade was worn off the blade was packed full of dirt. I didn't find that to be the case on machines with bolt on cutting edges. That went for all makes.
DGODGR
S/W CO
Hopefully you will find a great machine to buy when you go see it. Personally, I've not been a fan of those due to small over all feeling but specifically tight quarters in the cab and ingress/egress. I do like the baldes for that size machine though. Especially for a compact radius.
dieseldog5.9
New Hampshire
After looking and looking and looking, I found and bought the White Whale. Good thing because the better half was going to have me committed.
312CL, 5000hrs, not a ding in any of the panels, long stick.
Pics or it didn't happen.:D
Congrats! That's a nice looking 312.
First full size hoe I bought new was a 315CL and it was a great machine.
dieseldog5.9
New Hampshire
I am a simpler is better kind of guy, Cummins diesel trucks with manual transmissions, never bought DEF. I paid all the money but have been shopping for a 312 for 2 years, B or C would have been fine, looked at multiple machines hundreds of miles away that were trashed.
Have a 315B, 311, 307CL, 303.5DCR. We do a lot of septic systems, found the 311 to work well but needed a touch more reach.
Working on adding the Aux circuit for a thumb, but Cat discontinued, and have to use aftermarket or fab something up.
DGODGR
S/W CO
Me too!!...and mine has been good for me too! So far, that is. The meter is indicating about 9,000 hours now. I used her just the other day and she still works well!
DGODGR
S/W CO
In my opinion the "C" model machines are much better performers than the "B" models. I think you did well to have found one that clean and only 5k hours.
  • Like
Reactions: JPV
Our 321DL has 8K plus hours on the clock and I'd just as soon run it as our 325FL. Had to put a can of freon in it a couple of weeks ago and now she's cooling nicely.:D
dieseldog5.9
New Hampshire
Yes, My local Cat dealer quoted me an HKX Kit. $8500:( I am torn between buying the HKX kit from Cat, and being done with it, or coming up with another option.
They pulled the listing for cat aux lines so I cant look them up on SIS. Assuming Cat made the lines at some point, so there is a part number for them out there.
Mbar
North Carolina
Call USA attachments in king nc. They build progressive link thumbs as well as standard and fixed. I Plumed there first progressive link for them. It was a very nice thumb.
