The parts manual for your particular engine shows two 3/4" thread plugs on the top of the flywheel housing at approximately 10 & 2 o'clock.
It does not show any sensors mounted in that location. I suspect you are correct and that the sensor is a Grove part to provide a signal for the tachometer. In which case it will have nothing whatsoever to do with the engine starting issues you are experiencing.
