cbart
i'm new to the site and this is my first post. i recently purchased a used 2016 305e2 with about 1400 hours. This is my first experience with owning Cat equipment and over all I'm impressed with most aspects. However, I've noticed that while rotating the cab, the excavator will get hung up around 12:00 to 1:00 and and depending on where you stop, just passed 12:00 there is excessive slop as if a tooth is missing. Is there a way of inspecting the swing gear & bearing without removing the cab? Can it be viewed through the panels in the cab floor or from the underside? Is this an unusual problem given the low hours? Any advice would be greatly appreciated.
Regards,
Chris
Regards,
Chris
