We've had it since december but have only put roughly 20 hours on it. First time it's done this. One thing I forgot to mention is earlier in the day before these alarms showed up, it told me to increase engine rpm. I usually run the throttle on 9, once I put it up to 10 the message went away. Not sure if that helps
I am nowhere near being an expert on Tier 4 engines but that “increase engine rpm” message sounds suspiciously like exhaust after treatment-related to me. Everyone on here who posts about Tier 4 tells the same tale that to minimize potential DPF/DEF-related issues it is advised to run them flat out as much as possible. Apparently they do not like being run on low loads because it contaminates the after treatment package more rapidly.
From the Operation & Maintenance Manual regarding Regeneration Modes
Modes of Regeneration
Passive - Passive Regeneration occurs when the exhaust temperature is high enough for regeneration to occur. Passive regeneration may occur unnoticed by the operator. No operator action is required. Operating the machine above mid throttle and under load allows for passive regeneration during normal operation. Low idle and low load applications will have lower exhaust temperatures, where passive regeneration is not possible.
Active - An active regeneration is a late injection of fuel into the combustion chamber, which sufficiently raises the exhaust temperature for an active regeneration. The engine ECM uses multiple inputs from the engine to determine when an active regeneration is needed. All applications, even high load, will require active regenerations. However, active regeneration will not occur as frequently as low idle and low load applications
There will be a slight change in the exhaust noise during an active regeneration.
Active regenerations may require increased engine speed. The active regeneration may take up to 30 minutes to complete.
