This machine does not have a load sensing system.
From the information supplied by Nige;
The pump regulator changes the angle of the swashplate according to the flow that is required for a
machine operation. As the angle of the inclined surface of the swashplate changes, the stroke of pistons changes, and the pump output increases or decreases.
The main pump output varies from maximum output to minimum output according to the load on the
machine. The angle of the swashplate determines the actual output of the main pump.
So it does have a load sensing ability but not in the way you would expect.
Regards
Phil
