CAT 304e2 Bucket Drift
Discussion in 'Compact Excavators' started by bradleyt0515, Aug 20, 2022.
  1. bradleyt0515
    bradleyt0515 Member
    Apr 17, 2020
    11
    NY
    2018 Cat 304e2 CR.
    When the bucket is extended out it slowly drifts down. What could be the culprit?
  2. skyking1
    skyking1 Senior Member
    4,183
    does it stop drifting down when you raise the safety lever and shut off the pilot controls?
  3. Chrisso
    Chrisso Well-Known Member
    Apr 6, 2021
    227
    Diesel Mechanic
    Also, to stop any confusion, when the bucket cylinder is extended the bucket is in the curled position. If i interpret you correctly, what you're saying is the bucket drifts back down which means the bucket cylinder would be retracting while drifting.
    Or does the whole boom drift down when you poke the bucket all the way out?
  4. bradleyt0515
    bradleyt0515 Member
    Apr 17, 2020
    11
    NY
    When the bucket cylinder is retracted (bucket extended out, not curled) the bucket slowly drifts downward so the cylinder is essentially drifting outward. Bucket drifts towards the curl direction.
    Hope that makes sense
  5. skyking1
    4,183
    OK.
    Start the machine cold.
    Let it warm up and do nothing.
    Once it has warmed up the hydraulics, pick up the boom and stick, then hold the bucket in the curled position in bypass.
    If the cylinder is leaking internally, it will warm up.
  6. Chrisso
    Apr 6, 2021
    227
    Diesel Mechanic
    Skyking's question in post #2 is important, that can rule out a leaking pilot solenoid and the electrical side of things.
    If you can establish the cylinder isn't leaking internally, try swapping these line reliefs...
  7. uffex
    uffex Senior Member
    Jan 23, 2012
    3,141
    Admin
    Lincoln UK
    Good day
    Attached maybe of help, be aware that the boom & arm has creep prevention, whereas the bucket relies totally on the spool fitting in the slice. This results in a higher leakage for the bucket, checking the creep rate against specifications may save a lot of unnecessary work.
    Kind regards
    Uffex
  8. bradleyt0515
    bradleyt0515 Member
    Apr 17, 2020
    11
    NY
    I raised the safety lever and the bucket continued to drift towards the curl position.
