Cat 3000 Hour Code
Discussion in 'Compact Track/Multi Terrain Loaders' started by Kenskip1, Feb 23, 2020.
  1. Nige
    Nige Senior Member
    17,499
    But that's not what we were talking about............ that's the cat, not the DPF.
    The DPF is available as a Reman Part Number. Try pricing 20R-8036
    92U 3406 and Kenskip1 like this.
  2. 512high
    512high Well-Known Member
    Mar 4, 2014
    105
    new hampshire
    Ah ha! Nige/Mark you are correct, MUCH better! $1,451.67 w/core ...$1,827.50 w/o my mistake. Look I didn't want to hijack the thread, but, the large CAT engines (100 hp and up) that use DEF Fluid, when something goes bad(meaning emission stuff, are the parts more expensive then my 908M that doesn't use DEF Fluid? I'm just asking as a general question, I learned a lot on this thread!
    Kenskip1 likes this.
  3. John C.
    John C. Senior Member
    Jun 12, 2007
    8,960
    Lots changed when they got to Tier 4 Final and the use of DEF. DEF makes it so they can run the exhaust temperatures up again making for fewer particulates, less NOX production and far less soot production. The recommendations for ash removal changed drastically when the DEF systems were added. I've been out of the Cat system for more than two and half years now so maybe someone can comment on the newer systems.
  4. 92U 3406
    92U 3406 Senior Member
    Jan 3, 2017
    1,728
    North of there but east of here
    C3.3B in the skid steer line does not use SCR as its under the HP threshold. The C3.8 in the 299D/272D has an SCR catalyst. To my knowledge, only those 2 models use the C3.8.
  5. JD955SC
    JD955SC Senior Member
    Mar 14, 2011
    664
    The South
    Some of the Cat engines have also been updated to delete the EGR system and rely on DEF and DPF/DOC to control the emissions
    Kenskip1 and 512high like this.
  6. 92U 3406
    Jan 3, 2017
    1,728
    A step in the right direction IMO. Keep that emission crap off the engine.
  7. Byron fellows
    Byron fellows New Member
    Jan 17, 2020
    2
    Wrench
    Green cove springs, fl 32043
    My cat dealer just informed me of a 3 week turn around if they do the dpf....engine removal filter removal filter sent to be put in an oven for a week filter returned then tractor reassembled
  8. Nige
    Nige Senior Member
    17,499
    As a matter of interest did they quote you a price..?
  9. Byron fellows
    Jan 17, 2020
    2
    Wrench
    No they did not just informed me of how long i would be without my machine.....
  10. Nige
    Nige Senior Member
    17,499
    Why not ask them, just for sh1ts & giggles.? I'd be interested how much the estimate would be compared to a Reman DPF unit.
    Also get them to give you a detailed Parts breakdown of what they would put in it. It would be good info for anyone else who fancied a bit of DIY.
  11. Kenskip1
    Kenskip1 Well-Known Member
    Feb 13, 2019
    67
    Missouri
    Not to rub salt into the wound but how many hours are on the machine?
    512high likes this.
  12. 92U 3406
    Jan 3, 2017
    1,728
    On a skid steer? What size? I can turn one of those around in under 2 days if I've got the new parts sitting on the bench.
  13. 512high
    Mar 4, 2014
    105
    new hampshire
    * Did you say the engine has to come out? Maybe I miss read, if that is the case WTF!
  14. Nige
    Nige Senior Member
    17,499
    I’d seen that too. Hence the comment about getting a detailed quotation for the work the dealer was proposing to do, in addition to a list of the parts involved.
  15. 512high
    Mar 4, 2014
    105
    new hampshire
    Nige, Has to be wrong! At least on my 908M I can see the dam thing in my face, I never heard of a motor being pulled out to service that filter, but what do I know, agree, I would get things in writing regarding cost and so forth or seek an independent and maybe they would have CAT software to even reset code if required.....
  16. Nige
    Nige Senior Member
    17,499
    But on a skid steer the space above the engine is much more limited. Never having worked on one with emissions equipment fitted I have no idea if there is enough space between the engine and the roof of the engine cover to both access the hardware necessary to free the DPF, and then to remove the DPF out of the bodywork. If I can find a photo showing the engine compartment with the rear door open I’ll post it up.
  17. 512high
    Mar 4, 2014
    105
    new hampshire
    my mistake, I didn't think about that, those engines are crammed in there!
  18. 92U 3406
    Jan 3, 2017
    1,728
    I've done quite a few skid steer DPFs. I've always done it by going in from under the cab.
    The way its bolted onto the back of the engine its virtually impossible to remove the DPF/DOC mounting bolts with the engine in. They go up from the bottom. If you pull the firewall out, you can sit under the cab and they're right there.
  19. Tags
    Tags Senior Member
    Feb 19, 2012
    1,178
    Connecticut
    I'm sorry, but some dealers are just absolute dicks...."well sir, you'll be without your machine for three weeks, sorry we didn't mention that to you when you bought it, just tell your customers to wait, I'm sure they'll understand, sounds like you should have planned a vacation...."
    I'm sure that can't be right, any place that told me I'd be without the machine for three weeks because a serviceable part needs to be changed out would lose me as a customer immediately. What they told you just can't be right.....
    John C., Kenskip1 and 512high like this.
  20. 512high
    Mar 4, 2014
    105
    new hampshire
    I have to agree, especially a CAT? I don't know if CAT provides "in house" cleaning ? I am located in NH, my nearest CAT dealer is 16 miles away, and it is HUGH new facility! (very impressive) Next time I stop by , I will have to ask if they provide that service or maybe they have an exchange program, but your point is valid .
