Theese new fuel systems are Soo tight tolerances a little bit of water or dirt will wipe them out FAST! Essential to have clean fuel. Have done a few with gas being poured in the system and wiping pumps and injectors out fast also.
Save your old fuel lines and make caps out of them, then you can cap off the rail and see if pump builds pressure, eliminated fuel injectors as with the 299 injectors suck to replace under valve cover. Top fuel pressure relief is up to 30,000 psi now on these fuel systems so be careful but cautious.
