Jeffrey Bandel
I had a chance to look at the machine today. It's embarrassing, but I can't find the soft key. I have is a screen on the driver side which shows warning lights. It doesn't appear to be interactive.
I don't have that screen. I guess that puts me back to square one.
Yes on the display.You have the “Basic” display with one gauge (fuel) and 6 buttons to the right, correct? The DPF lamp which is illuminated (as you have stated) generally means the machine is in regen but can also indicate a fault in the aftertreatment system.. its possible that the machine is derating itself due to an active fault for the aftertreatment system
When you experience the issue are you able to throttle up at all?
Just trying to gain some insight
My gut says speed sensor, as it locks you out only after moving 6 inches. There is one on each drive, IIRC.
