Jeffrey Bandel
I have tension now. I had to move it 4 or five times and grease in between but it looks like it is holding.
Have you tested to see if there is 12 volts on the output of the solenoid (item #6) when you have it clicking? Two things need to be good for starter to crank engine, the solenoid and the motor of the starter. I would hate to see you buy a new solenoid and mount it only to find the real problem was in the starter motor!Thanks. You and I are right. My manual is wrong.
I removed the white lead that provides 12V to the solenoid. I hooked up a wire directly to that lead and the positive terminal of the battery with the key on. The solenoid just clicks. Can you buy just the solenoid or do I have to fork out $600 for the whole starter assembly?
Exactly.I think I would put a barrel Anfo under that thing, invite your neighbors and spread CAT poop everywhere by now. Your patience is inspiring.
