Acoals
Hi guys, I have a 289D, serial 0289DVTAW01488. The symptoms I have are when the hydraulics are hot, it really doesn't show up in the winter or for the first half hour of operation. When traveling in low speed, and shifting into high, the machine will slew hard to one side, you have to input hard stick correction to compensate. When shifting back down into low gear, the machine slews hard the other direction. After shifting into high, it will straiten out, but only after rather prolonged correction. Once it is running straight, it will not run as fast as it ought to, up to 3mph slow.
I was told by the dealer I bought the machine from that this is a common problem relating to a swash plate issue in the drive motors, which Cat has remedied with a service bulletin and updated part. Basically the problem is a lazy shifting side and the PCM compensating for reduced track speeds by slowing the other side's flow.
What I am looking for is either opinions on the cause of the problem, or information on Cat's updates. My understanding of hydraulics is limited, so I am little fuzzy on what the swashplate is doing and how, (and what it isn't doing, in this case).
