77v46a
New to this site looking for any info or advice on our cat 287 serial number cny.
It seems that the right track brake is dragging and sometimes will stop machine all together. We have performed basic hydraulic test everything is in spec except the charge pressure at low idle. Charge is good at high idle. We changed charge and implement pump and still have same symptoms. The implement side of the double gear pump must have been worn because bucket response and strength is much better. I think we have a internal leak hydrostatic pump or drive motor? Any advice? We did test the brake silionode, works but only have the low pressure about 200 to 240, spec is 465 psi. Is charge pressure what releases the brakes? Thanks
