S/N KWB01063 with HIGH FLOW XPS
Jumper Plug P/N 2413763
Both 15A fuses in the hydraulic cylinder slots in cab fuse panel are good. The operator manual has very little information on how this system works, so I'm mostly putting snippets together from Google searches. Initial testing was done with 1&2 rocker down on continuous flow. I did swap my hoses so that the operating direction is auxiliary 1&2 rocker up, but have not retested. I thought that pins B & F should be jumped for high flow?
