Matt Matsuzaka
Hello I am new to this Forum.
I bought 2011 Cat 279C and I am having a few problems serial MBT02200.
First the alternator died I took it in and have it tested it was died. So I bought a new one installed it and its not charging. I checked the voltage on the on the signal wire with the key on engine off and I’m getting 8V. Still no charging I checked all fuses everything is good. I did read on here something about a main breaker, but I cannot find one on my machine. Maybe I just not looking in the right place. I did replace the battery with a new cat batter because the old one was over 3 years old. The yellow light with the ! is flashing in the cab.
The second problem is that if I fill my radiator full it dumps in the overflow on the door and runs out on the ground. Is this a bad radiator cap? Or is there supposed to be a one-way valve to keep the coolant from running down to the overflow bottle?
Thank you for you help.
