truecountry
Ok SN is jwf00391
My problem is it will not crank after it gets hot ..no power to the solenoid on starter when key is on
Brand new cat starter and same problem noway I have 2 bad starters,,,and Voltage is good at battery .Swapped relays with Air Conditioner and same part number and same problem ..no start no clicking nothing .....
I see in wiring diagram it has a Neutral safety switch but I cant find it
The key switch feels rough to turn , haven't pulled it out to check yet
As I looked at diagram its
Key switch
neutral safety
arm rest sensor ...Checked good
windshield door sensor ...checked good
seat sensor ...checked good
ecm....Don't think ecm is bad
relay ...swapped
solenoid new
and starter new
Have I missed something ?
Key switch
neutral safety
relay ...swapped
solenoid new
and starter new
