Cat 277b Aux hylraulics running slow
Discussion in 'Compact Track/Multi Terrain Loaders' started by 63 caveman, Sep 13, 2018.
  1. 63 caveman
    63 caveman Well-Known Member
    Nov 11, 2017
    125
    western Pa.
    Hello all,
    I'm tring to figure out a slow aux. hyro problem, serial # MDH00903 with standard pump (no high flow). I have 7.9 vdc between pins 1 and 2 on right joystick 12 pin connector and have 53.3% in neutral on pin 3 going smoothly between 56.9% to 43.0% with thumb wheel.
    All other hydro function work at normal speed.
    Are the % readings in normal range?
    DO you think I may have a leaking (bypassing internal) Aux. spool valve?
  2. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    809
    heavy equipment technician
    victoria,Australia
    no the duty cycle is way to low
    The voltage to the controller is 8 VDC so that is ok
    Mark
  3. 63 caveman
    Nov 11, 2017
    125
    western Pa.
    Thanks Mark, I checked another machine and it went from 20% to 80% just like the graph you posted. $400 USD later for new switch and it is working right. It would have been easy for me if it was just dead.
    Thanks Again
