Posting this in case it helps someone else, I couldn't find anyone that had fixed it or found an aftermarket option. Cat 236b 2006?. Seems to be common problem. I fixed the rocker switch for the auxiliary hydraulics for 236b. Auxiliary hydraulics not working. After pulling apart the machine to check solenoids, wiring to ECU floor plate etc, took apart the joysticks, took out the rocker switch. by carefully prying apart at both ends (thin plastic) removed the thumbwheel, there were what looked like the remnants of a magnet attached to thumbwheel. Couldn't afford the new joystick $500 from westrac. Took 2 x kids toy magnets, ball magnets approximately 3-4mm diameter, drilled both sides of thumbwheel where magnet remnants to create a small depression with a 4mm drill bit. Hot glue gun placed a small daub of glue and pressed magnet into position on each side of rocker switch, stuck to steel first to check orientation of magnet pole, removed and placed same orientation into depression, so it just cleared the base of the switch with the rocker in place. glue gun filled the spaces between and around the magnets. Knife to trim excess glue. first checked switch worked without reassembling with springs, just holding rocker switch in place against switch base (the bit with the electronics) etc. once working reassembled rocker switch and joystick. Some points, rocker switch has to be working for auxiliary hydraulics to work.
If anyone knows where to get after market thumb rocker switch let me know.
If auxilary hydraulics not working for cat skid steer and you have one of these rocker switches suggest checking this first rather than pull apart machine.
